Router Recommendation
Hi, We are in the process of replacing our head office router which supports a 400/400 mbps link. Head office only has 30 users.
We also have 2 remote sites which VPN to us, a total of 15 remote users.
Was wondering if I could get some help on a suitable Mikrotik router.
Our research has led us to either RB1100AHx2 or CCR1009-8G-1S-1S+. Or are they both overkill?
Would welcome any suggestions, advise or recommendations on a suitable device.
Thanks in advance.
good choice
any reference under 1100ahx2 will not be enough
between 1100ahx2 and ccr 1009 i will go with ccr 1009, price difference its 40% but performance its 300% better at least
and its more future proof because its 9 core cpu
If you’re not going to be doing any IPSEC tunnels the CCR would be a better choice.
Thanks all, much appreciated
