Router Suggestion for Serviced Office
Good day,
We are currently setting up a serviced office with 30 tenants. A typical tenant only has 2 or 3 employee using their office, sometimes 1 only.
Maximum client is at around 50-100 max, office spaces are fairly small and can only fit up to 2-3 persons.
ISP speed is up to 1000/1000mbps. Our plan is to create 30 vlans, each client has their own vlan and subnet.
We also plan to deliver 50/50max to each client.
Can the RB1100AHX4 handle this type of setup?
Thank you!
Checked with our vendor, RB1100AHX4 is not available.
Other choices based on cost:
  1. CCR2004-16G-2S+
  2. CCR1009-7G-1C-1S+
Can you recommend which one is the best router for our setup.
Thank you!
