Router suggestions
I’ve just got an LHG LTE6 and would like to pair it up with a wifi router. It would be great if I can find something that has POE passthrough so I can power both the router and the LHG from a single plug. Can anyone suggest a router model for this?
Thanks!
You can look at hAP ax3, passive poe out on ether1, 24V but LHG have poe input range from 12 to 57V and only 6W power draw so it should work.
Or if you want something cheaper and smaller then go for hAP ax2
Great. The HAP ax2 looks perfect for my needs. Thanks.
No problem.
But one more thing to mention, hAP ax2 doesn’t have USB port, so if you are planning to use containers you should either get ax3 or use SMB and rose storage.
