Mikrotik hardware and ROS have opened an interesting and fun rabbit hole for me!
I have acquired 2 L009 devices and am playing with them in a test setup before moving them to my home network. They both run ROS 7.19.4 with the appropriate matching firmware updates. One (router-1) is set up to provide router + access ports and the other (switch-1) to only provide switch functionality. The sfp ports provide the inter-device trunk. Ether1 on the router is the WAN port and is connected as a dhcp client to my ISP fiber via an ONT that provides basic firewall services. Router-1 has the default Mikrotik firewall active. For now, I have off bridge ports configured on both devices. With both devices in their default state (no vlans setup) all functions well. But with my current vlan setup there are problems.
Router-1:
| Physical | Function/VLAN | VLAN ID | Subnet |
| ether1 | WAN | dhcp client | |
| ether2 | OffBridge | 192.168.75.0/28 | |
| ether3 | Management | 99 | 192.168.0.0/24 |
| ether4 & 5 | PC | 10 | 10.0.10.0/24 |
| ether6 | Guest | 20 | 10.0.20.0/24 |
| ether7 & 8 | IOT | 30 | 10.0.30.0/24 |
| sfp | Trunk | 1 |
Switch-1:
| ether1 | Management | 99 | 192.168.0.0/24 |
| ether2 & 3 | PC | 10 | 10.0.10.0/24 |
| ether4 & 5 | Guest | 20 | 10.0.20.0/24 |
| ether6 & 7 | IOT | 30 | 10.0.30.0/24 |
| ether8 | OffBridge | 192.168.76.0/28 | |
| sfp | Trunk | 1 |
With the current setup Router-1 seems to function mostly as expected. I have access to the web with ping and with a browser from the various vlan access ports. Curiously nslookup does not work on the PC, Guest & IOT vlans. The vlans are properly segregated. The management port on the router can open WinBox on the router and also on the switch.
Switch-1 can open WinBox on the switch and on the router from the management port. From the management port only pings 192.168.0.1 and to the web succeed. The browser succeeds but nslookup fails. From the PC vlan ports pings to all *.1 ips in the LAN work as do pings to the web (eg ping 1.1.1.1). However, nslookup yahoo.com fails. The browser succeeds in reaching yahoo.com. Within a vlan (eg vlan id 10) one host cannot ping another. DHCP seems to function on both the router and the switch.
These behaviors show that I clearly do not have the two devices correctly setup. The exported setups for each are below. If requested I can upload the verbose versions of the exported files.
Can someone suggest where I have gone wrong?
Switch-1
# 2025-07-29 19:36:47 by RouterOS 7.19.4
# software id = IZ2D-1YF9
# model = L009UiGS
# serial number = HHG0A5XTN3E
add name=BR1 vlan-filtering=yes
/interface vlan
add interface=BR1 name=Guest vlan-id=20
add interface=BR1 name=IOT vlan-id=30
add interface=BR1 name=Management vlan-id=99
add interface=BR1 name=PC vlan-id=10
add name=OFFBR
add name=LAN
add include=OFFBR,LAN name=OFFBRandLAN
add name=OffBR-Pool-L009 ranges=192.168.76.2-192.168.76.14
add address-pool=OffBR-Pool-L009 interface=ether8 name=OffBridge-dhcp-serv
/port
set 0 name=serial0
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=\
ether1 pvid=99
ether2 pvid=10
ether3 pvid=10
ether4 pvid=10
ether5 pvid=20
ether6 pvid=20
ether7 pvid=30
add bridge=BR1 frame-types=admit-only-vlan-tagged interface=sfp1
set discover-interface-list=OFFBRandLAN
/interface bridge vlan
add bridge=BR1 comment=Management tagged=sfp1,BR1 untagged=ether1 vlan-ids=99
add bridge=BR1 comment=PC tagged=sfp1 vlan-ids=10
add bridge=BR1 comment=Guest tagged=sfp1 vlan-ids=20
add bridge=BR1 comment=IOT tagged=sfp1 vlan-ids=30
add interface=ether8 list=OFFBR
add interface=BR1 list=LAN
add interface=Management list=LAN
add address=192.168.76.1/28 comment="Off Bridge" interface=ether8 network=\
192.168.76.0
add address=192.168.0.2/24 comment=Management interface=Management network=\
192.168.0.0
add address=192.168.88.2/24 interface=BR1 network=192.168.88.0
add address=192.168.76.0/28 dns-server=192.168.76.1 gateway=192.168.76.1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=sfp1 routing-table=\
main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=10.0.10.0/24 gateway=PC routing-table=main \
/system clock
set time-zone-name=America/Chicago
/system identity
set name=Switch-1
/system routerboard settings
set auto-upgrade=yes enter-setup-on=delete-key
/tool mac-server
set allowed-interface-list=OFFBRandLAN
/tool mac-server mac-winbox
Router-1
# 2025-09-05 09:34:00 by RouterOS 7.19.4
# software id = 2Y0J-5V4S
# model = L009UiGS
# serial number = HGA09ZQDNJ0
add admin-mac=D4:01:C3:68:A9:1F auto-mac=no comment=BR1 name=BR1 \
port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="Off Bridge"
/interface vlan
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=OFFBR
add name=OffBridge-Pool ranges=192.168.75.3-192.168.75.14
add name=PC-Pool ranges=10.0.10.10-10.0.10.254
add name=Guest-Pool ranges=10.0.20.10-10.0.20.254
add name=IOT-Pool ranges=10.0.30.10-10.0.30.254
add name=Management-Pool ranges=192.168.0.10-192.168.0.254
add address-pool=OffBridge-Pool comment="Off Bridge" interface=ether2 name=\
OffBridge-dhcp-serv
add address-pool=PC-Pool comment=PC interface=PC name=PC-dhcp-serv
add address-pool=Guest-Pool comment=Guest interface=Guest name=\
Guest-dhcp-serv
add address-pool=IOT-Pool comment=IOT interface=IOT name=IOT-dhcp-serv
add address-pool=Management-Pool comment=Management interface=Management \
name=Management-dhcp-serv
/port
set 0 name=serial0
add bridge=BR1 comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 \
internal-path-cost=10 path-cost=10 pvid=99
admit-only-untagged-and-priority-tagged interface=ether4 \
internal-path-cost=10 path-cost=10 pvid=10
admit-only-untagged-and-priority-tagged interface=ether5 \
admit-only-untagged-and-priority-tagged interface=ether6 \
internal-path-cost=10 path-cost=10 pvid=20
admit-only-untagged-and-priority-tagged interface=ether7 \
internal-path-cost=10 path-cost=10 pvid=30
admit-only-untagged-and-priority-tagged interface=ether8 \
add bridge=BR1 comment=defconf frame-types=admit-only-vlan-tagged interface=\
sfp1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ip settings
set max-neighbor-entries=14336
/ipv6 settings
set max-neighbor-entries=7168
add bridge=BR1 comment=IOT tagged=sfp1,BR1 vlan-ids=30
add bridge=BR1 comment=Guest tagged=sfp1,BR1 vlan-ids=20
add bridge=BR1 comment=PC tagged=sfp1,BR1 vlan-ids=10
add bridge=BR1 comment=Management tagged=sfp1,BR1 untagged=ether3 vlan-ids=99
add comment=defconf interface=BR1 list=LAN
add interface=ether2 list=OFFBR
/interface ovpn-server server
add mac-address=FE:17:CA:6F:03:26 name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=BR1 network=\
192.168.88.0
add address=192.168.75.1/28 comment="Off Bridge" interface=ether2 network=\
192.168.75.0
add address=10.0.10.1/24 comment=PC interface=PC network=10.0.10.0
add address=10.0.20.1/24 comment=Guest interface=Guest network=10.0.20.0
add address=10.0.30.1/24 comment=IOT interface=IOT network=10.0.30.0
add address=192.168.0.1/24 comment=Management interface=Management network=\
192.168.0.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address-pool=*1 interface=BR1 lease-time=10m name=defconf
add address=10.0.10.0/24 comment=PC gateway=10.0.10.1
add address=10.0.20.0/24 comment=Guest gateway=10.0.20.1
add address=10.0.30.0/24 comment=IOT gateway=10.0.30.1
add address=192.168.0.0/24 comment=Management gateway=192.168.0.1
add address=192.168.75.0/28 comment="Off Bridge" dns-server=1.1.1.1,8.8.8.8 \
gateway=192.168.75.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=Router-1
/tool mac-server
