Hi all,
I’m looking for recommendation on which device to buy.
With requirements below:
- It edge device and is used for out of band management to the infrastructure
- VPN(IPSEC,PPTP,L2TP)
- Support for Dude with onboard M2/SATA storage
- At least 20 1Gbit Ethernet ports
- Dual PSUs
At the moment we are using CCR1036-12G-4S and it works fine albeit underutilized as we do not push a lot of traffic. The problem with it is the lack of ports.
As we started running out of ports we started using SFP to RJ45 but these are no reliable and I would prefer native EJ45 ports.
Is there a device that would fit the bill? If not, which switch would you recommend to attach to CCR1036-12G-4S
