Hi everyone !
Newbie on the subject here trying to make it work !
I’m using a Hex Router which has 2 VRFs because my 2 WANs use the same type of IP. I am able to access the Internet with my router with the routes that I have but I’m unable to use the DNS servers with my router whereas my LAN can.
[admin@MikroTik] > /ip/route print detail
Flags: D - dynamic; X - disabled, I - inactive, A - active;
c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn; H - hw-offloaded; + - ecmp
0 As dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=192.168.130.1@R_VRF1 immediate-gw=192.168.130.1%ether1 distance=1 scope=30
target-scope=10 suppress-hw-offload=no
1 As dst-address=0.0.0.0/0 routing-table=R_VRF2 pref-src="" gateway=192.168.130.1@R_VRF2 immediate-gw=192.168.130.1%ether2 distance=1
scope=30 target-scope=10 vrf-interface=ether2 suppress-hw-offload=no
DAc dst-address=192.168.130.0/24 routing-table=R_VRF2 gateway=ether2@R_VRF2 immediate-gw=ether2 distance=0 scope=10 suppress-hw-offload=no
local-address=192.168.130.253%ether2@R_VRF2
2 As dst-address=0.0.0.0/0 routing-table=R_VRF1 pref-src="" gateway=192.168.130.1@R_VRF1 immediate-gw=192.168.130.1%ether1 distance=1
scope=30 target-scope=10 vrf-interface=ether1 suppress-hw-offload=no
DAc dst-address=192.168.88.0/24 routing-table=R_VRF1 gateway=bridge-1@R_VRF1 immediate-gw=bridge-1 distance=0 scope=10
suppress-hw-offload=no local-address=192.168.88.1%bridge-1@R_VRF1
DAc dst-address=192.168.130.0/24 routing-table=R_VRF1 gateway=ether1@R_VRF1 immediate-gw=ether1 distance=0 scope=10 suppress-hw-offload=no
local-address=192.168.130.131%ether1@R_VRF1
It bothers me because I need my Router to use DNS servers in order to update it. Note that my router can still ping any IP such as 8.8.8.8 as long as it’s not a domain.
[admin@MikroTik] > ping 8.8.8.8 count=10
SEQ HOST SIZE TTL TIME STATUS
0 8.8.8.8 56 115 10ms567us
0 8.8.8.8 56 115 10ms758us
1 8.8.8.8 56 115 10ms188us
1 8.8.8.8 56 115 10ms406us
2 8.8.8.8 56 115 10ms649us
2 8.8.8.8 56 115 10ms829us
3 8.8.8.8 56 115 10ms674us
3 8.8.8.8 56 115 10ms863us
4 8.8.8.8 56 115 11ms17us
4 8.8.8.8 56 115 11ms204us
sent=5 received=10 packet-loss=-100% min-rtt=10ms188us avg-rtt=10ms715us max-rtt=11ms204us
[admin@MikroTik] > ping google.fr count=10
invalid value for argument address:
invalid value of mac-address, mac address required
invalid value for argument ipv6-address
while resolving ip-address: could not get answer from dns server
Also I don’t understand why I receive the double that I send when I ping, it’s not too important but if you guys have an explanation it would be nice.
I tested a ton of things that didn’t work. I tried making firewall rules for tcp and udp protocols going though my vrf interface, making all sort of routes and much more…
Here’s my full config, it’s my test config so there’s a lot of stuff disabled.
# jun/21/2023 16:12:58 by RouterOS 7.9.1
# software id = ZLYE-A3CY
# model = RB750Gr3
# serial number = -
add admin-mac=- auto-mac=no comment=1 name=bridge-1
add comment=2 disabled=yes name=bridge-2
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=pool-1 ranges=192.168.88.10-192.168.88.254
add name=pool-2 ranges=192.168.130.10-192.168.130.254
add address-pool=pool-1 interface=bridge-1 name=DHCP-1
add address-pool=pool-2 interface=bridge-2 name=DHCP-2 server-address=\
192.168.130.1
/ip vrf
add interfaces=ether1,bridge-1 name=R_VRF1
add interfaces=ether2,bridge-1 name=R_VRF2
/port
set 0 name=serial0
/system logging action
set 1 disk-file-count=50
add bridge=bridge-2 comment=bridge-2 interface=ether5
add bridge=bridge-1 comment=bridge-1 interface=ether4
add comment=defconf interface=bridge-1 list=LAN
add interface=bridge-2 list=LAN
add interface=ether2 list=WAN
add address=192.168.88.1/24 comment="Bridge 1" interface=bridge-1 network=\
192.168.88.0
add address=192.168.130.1/24 comment="Bridge 2" interface=bridge-2 network=\
192.168.130.0
/ip dhcp-client
add add-default-route=no comment="WAN 1" interface=ether1 use-peer-ntp=no
add add-default-route=no comment="WAN 2" interface=ether2 use-peer-ntp=no
add add-default-route=no comment="WAN 1-TEST" interface=ether3 use-peer-dns=\
no use-peer-ntp=no
add address=192.168.88.0/24 comment="Bridge 1" dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.88.1
add address=192.168.130.0/24 comment="Bridge 2" dns-server=8.8.8.8,8.8.4.4 \
set allow-remote-requests=yes servers=192.168.130.1
/ip dns static
add address=192.168.130.1 comment=defconf name=router.lan
add action=drop chain=output comment="Desac 8.8.8.8" disabled=yes \
dst-address=8.8.8.8 protocol=icmp
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
established,related,untracked disabled=yes
connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=output dst-port=53 new-routing-mark=R_VRF1 \
out-interface=ether1 passthrough=yes protocol=udp
out-interface=ether1 passthrough=yes protocol=tcp
add action=accept chain=prerouting protocol=icmp
add action=accept chain=prerouting disabled=yes protocol=icmp src-address=\
192.168.130.0/24
add action=mark-routing chain=prerouting comment=Bridge-1 disabled=yes \
dst-address=0.0.0.0/0 new-routing-mark=R_VRF2 passthrough=yes \
src-address=192.168.88.0/24
add action=mark-routing chain=prerouting disabled=yes dst-address=0.0.0.0/0 \
new-routing-mark=*1 passthrough=yes src-address=192.168.88.0/24
add action=mark-routing chain=prerouting disabled=yes dst-address=\
192.168.88.0/24 new-routing-mark=main passthrough=yes src-address=\
0.0.0.0/0
add action=mark-routing chain=prerouting disabled=yes new-routing-mark=R_VRF1 \
passthrough=yes src-address=192.168.130.0/24 src-address-type=""
add action=mark-routing chain=prerouting comment=Bridge-2 disabled=yes \
new-routing-mark=main passthrough=yes src-address=192.168.130.0/24
192.168.130.0/24 new-routing-mark=main passthrough=yes src-address=\
0.0.0.0/0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.130.1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.130.1@R_VRF1 \
pref-src="" routing-table=R_VRF1 scope=30 suppress-hw-offload=no \
target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup disabled=no dst-address=0.0.0.0/0 routing-mark=main \
src-address=192.168.88.0%bridge-1/24 table=*1
add action=lookup disabled=no dst-address=192.168.88.0%bridge-1/24 \
routing-mark=*1 src-address=0.0.0.0/0 table=main
/system clock
set time-zone-name=Europe/Paris
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add disabled=yes interval=1d name=delete-logs on-event="/*\$jour = 20 ;\r\
\n\$rep = /flash/log;\r\
\n\$time = \$rep->\"time\";\r\
\n\r\
\n:if (\$rep > \$jour) do={\r\
\n\r\
\n}*/\r\
\n\r\
\n:local jour 20;\r\
\n\r\
\n/log print where time<(\$now-\$jour * " policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=jun/01/2023 start-time=17:40:37
add interval=5s name=ping-fail on-event=":global route;\r\
\n\r\
\n# route principale\r\
\n:if ([/ping 8.8.8.8 count=3] = 3 && \$route != \"a\") do={\r\
\n /ip/vrf/move 0 1;\r\
\n :set \$route \"a\";\r\
\n};\r\
\n\r\
\n# route secondaire\r\
\n:if ([/ping 8.8.8.8 count=3] = 0 && \$route != \"b\") do={\r\
\n /ip/vrf/move 1 0;\r\
\n :set \$route \"b\";\r\
\n};" policy=\
start-date=jun/20/2023 start-time=11:07:59
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=yes down-script="" host=8.8.8.8 http-codes="" interval=10s \
test-script="" type=icmp up-script=""
add disabled=yes down-script="" host=1.1.1.1 http-codes="" test-script="" \
type=simple up-script=""
I hope that I provided enough informations and that I was clear despite my lack of knowledge.
