I’ve been using a RB750GL for a long time and been very happy with it.
A month ago I’ve switched ISP to a faster one.
I noticed the CPU become a bottleneck and turned on fasttrack.
At the same time I’ve also upgraded from 6.45.9 to the then latest version 6.47.1
Since that the router randomly becomes unresponsive: port lights are keep flashing but I can not connect by any means not even ping it.
Plugging in/out any or all UTP cables makes no different, I need to power cycle it.
Then it will keep working perfectly and fast anywhere from a minute to a week, average uptime 4 days.
Before this change it would run for years.
At first I assumed the faster connection induced heavier load and replaced the power adapter, but now I’m over the third adapter and the issues persists.
In retrospect it was a silly assumption as fasttrack lowered the load by large.
Naturally there were a number of other changes at the time of the ISP changing, fasttrack is only my best bet being the change that have never been on this router done before.
Today browsing these forums I noted there were issues with fasstrack earlier, so I updated to the current LTS release 6.48.5.
However there’s nothing in the release notes about fasstrack.
I’ve considered switching to the latest stable but did not as I’ve seen no fasstrack bug fixed there either.
ATM I am unsure I’m still sitting on a time bomb, so advice is welcome.
For the record router on stable/6.49.1 is now up and running for 10 days. Looking good! @msatter yes, fw is on 6.49.1 too.
Might or might not be related but 6 days ago I’ve removed all mangle rules as the next step of phasing out the old internet link. They were used to mark conection and routing for connections still coming in on the old link. Also the exclusion of the corresponding interface from the fasstrack rule and the routing mark from the 0.0.0.0 route has been removed.
4 days passed and the brand new 750GL halted to death.
I assume it’s not a one-off hw defect, but a software one, and also assume it’s related to fasstrack.
Does anyone know if the manufacturer offers support for this product?
I would be happy to help with logs and running debug builds to locate and fix this error.
I don’t think it should crash, and in my experience this rarely ever happens with MikroTik routers, but on the other hand this is a low-end device and when you tell us that “you got a faster ISP” it may be the time to upgrade to a faster router.
(depending on what that means. e.g. when it is 20Mbit/s instead of 10Mbit/s no problem, but for 100Mbit/s and faster these routers really are too slow)
For our use case switching to a recent, more perfomrant model would only help when concurrent use is high and the device cpu becomes a bottleneck. Looking at the CPU usage graph it’s very rare, so this device would be great for us for a long time. (5min average cpu is under 15%, memory is at 30%, disk has plenty of space.)
As all tests point towards the issue being software related, I don’t feel confident if a more performant hw - running the same problematic sw - would really solve the issue.
Being a sw dev myself, I think here we got a configuration reproducing an issue - I see this as an opportunity to catch this bug. Perhaps it pops up on other hw too, just much less frequently.
Talked to support, upgraded to rOS 7.1.2 then 7.1.3, still halting.
For the record, watchdog did not help as it could not generate an autosupout when halted, supouts saved just after powercycling did not help them.
However later I noticed a strange bandwidth asymmetry of traffic, traffic from the server were at half-ish speed. Duplex setting were OK. Then I realized only TCP is affected, but TCP settings were identical on both sides.
Wireshark showed the difference is in ethernet frames, 7KBytes to server, 60KBytes from server. There were 8 ACK to every huge frame sent.
I’ve switched off TSO on the server NIC with ethtool a week ago, has not seen a halt since.
To my great dismay after 30 days to router halted again. Than again in a week. Then again in a day. Halts are even more random now.
Looks like setting TSO off on the connecting device does not solve the issue but made it less reproducible.
Today I’m upgrading from 7.1.3 to 7.2.1, but it’s unlikely the problem will magically go away.
I could not live with the unstability any more, and it looks like Mikrotik does not really care that much about this reproducible halt issue that requires manual intervention.
At least their support is responding on email.
Anyway, I’m getting a Hex now, hoping it being recent got better testing with the latest RouterOS, and if not, maybe the issue gets more attention.
I recommend that you use the @Anav firewall configuration method. https://forum.mikrotik.com/viewtopic.php?t=180838
Your firewall configuration is not really correct. And - fasttrack never puts a firewall in the beginning! The sequence of firewall rules greatly affects the overall performance of the router.
