i want to use MikroTik as a virtual Router in my ESXi setup. But my hoster has me assigned an ip address for this router vm which i couldnt get configured right on my MikroTik.
He gave me this setup description for debian/ubuntu and windows:
/etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 6.199.143.192
netmask 255.255.255.255
post-up ip route add 218.79.179.1 dev eth0
post-up ip route add default via 218.79.179.1
Windows:
netsh interface ip set address name=“LAN-Connection“ static 6.199.143.192 255.255.255.255 218.79.179.1
Is it possible to set such routes in the MikroTik Router? I think two routes are needed like in the debian setup. But i tried, and the web interface says “unreachable” for the Default GW route.
Okay i think MikroTik cant handle a default gateway outside of the wan interface address network.
I tried it with lowering the scope of the host route and setting the default gw route to a higher target-scope. But he will just not send the traffic out. The following configuration works with CentOS:
[root@localhost ~]# LANG=en_US ifconfig
eth0 Link encap:Ethernet HWaddr 00:0C:29:56:49:44
inet addr:6.199.143.192 Bcast:6.199.143.192 Mask:255.255.255.255
inet6 addr: fe80::20c:29ff:fe56:4944/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:90072 errors:0 dropped:0 overruns:0 frame:0
TX packets:31500 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:81134725 (77.3 MiB) TX bytes:2335707 (2.2 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
[root@localhost ~]# LANG=en_US route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
218.79.179.1 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
169.254.0.0 0.0.0.0 255.255.0.0 U 1002 0 0 eth0
0.0.0.0 218.79.179.1 0.0.0.0 UG 0 0 0 eth0
