Few days after the SFP replacement the problem has returned. It reboots 3-5 times a day randomly. I’ve tried every stable RouterOS release since that and it didn’t help. I can’t provide any supout because it’s not created. I’ve set all logging to disk but nothing had written.
Hey everyone, any update on this?
I’m having the same issue. My hap ac lite keeps rebooting itself because of the watchdog. If I disable the watchdog, the entire unit becomes unresponsive and I have to power cycle it myself.
I’m on the latest stable firmware, and have also tried the latest beta.
I have tried the power supply from a 750G, but not sure if it’s powerfull enough, so may show the same symptoms.
Bump?
I have the exact same issue.. The Hap Ac reboots a few times a day with that error message. I noticed it happens the most at downloading large files or streaming videos. This problem persists since a year now and I always downloaded latest packages and firmware. I also did a reconfiguration twice and ended up buying a new one, and guess what? The new router does the same thing!
It’s really disappointing that Mikrotik don’t care about that problem. How should I use the routers for my customers if I don’t even know that they work like expected? This problem seams to exist since 2013 when you look at this thread.
I really would appreciate a solution for that!
I experienced this behavior on HAP ac after 42 days of uptime and heavy torrenting. My educated guess is that there is a memory overflow issue somewhere.
So I updated the router to 6.45.6. The long-term 6.44.5 performed weird for me.
Also, try disabling Internet detect function. After doing this, my router is much snappier. Router’s log also stopped being flooded with Internet Detect messages.
I am telling you this, because my issues started aroud the time Internet detect function was introduced.
However, I cannot provide you with any proof that this will help you.
- If reboots persist, then generate supout file on router (and latest RouterOS version installed) and send it to support@mikrotik.com
I was send too “MikroTik support #[SUP-98849]:” RB411 6.48.6.
i have a similar problem, but in this case… wen i lost power from my power supplier and once its back online it doe occurs from there all the vouchers i created and are already in use will all restart new session time .so i was asking is there any solution to that, like after regaining power supply
