Hello guys,
I’m trying to achieve easy things (in my opinion of course)
What I need is a router with few VLANs and router’s local ports acting as a Access Ports.
Eth1=WAN, Eth2=Access Port for VLAN88, Eth3=Access Port for VLAN99, Eth4=Access Port for VLAN100, Eth5=TRUNK carrying out all VLANs tagged.
I wish to have VLANs isolated from each other, I need ether3 to be a hybrid port (access for VLAN99, trunk for Vlan100) and few more, but today even basic functionality is not working.
PC connected to any of access ports is not getting IP, when I set manually IPPC cannot ping gateway.
I spent a lot of time reading and I got lost. Nothing is working, and I have no idea why …
My config was adopted to my needs from Using RouterOS to VLAN your network - Useful user articles - MikroTik community forum router.rsc file
Could you guide me what’s wrong with my config?
I’m using RouterBOARD 750G r3 6.49.19 with MediaTek MT7621 build in switch.
Topic: Using RouterOS to VLAN your network
Example: Switch with a separate router (RoaS)
Web: Using RouterOS to VLAN your network - Useful user articles - MikroTik community forum
RouterOS: 6.43.12
Date: Mar 28, 2019
Notes: Start with a reset (/system reset-configuration)
Thanks: mkx, sindy
Naming
name the device being configured
/system identity set name="Router"
VLAN Overview
1 = CCTV
88 = PPoE
99 = MGMT
100 = WiFi
Bridge
create one bridge, set VLAN mode off while we configure
/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
-- Trunk Ports --
ingress behavior
Purple Trunk. Leave pvid set to default of 1
add bridge=BR1 interface=ether5
add bridge=BR1 interface=ether2 pvid=88
add bridge=BR1 interface=ether3 pvid=99
add bridge=BR1 interface=ether4 pvid=100egress behavior
/interface bridge vlan
Purple Trunk. These need IP Services (L3), so add Bridge as member
add bridge=BR1 tagged=BR1,ether5 vlan-ids=1
add bridge=BR1 tagged=BR1,ether5 untagged=ether2 vlan-ids=88
add bridge=BR1 tagged=BR1,ether5 untagged=ether3 vlan-ids=99
add bridge=BR1 tagged=BR1,ether5 untagged=ether4 vlan-ids=100#######################################
IP Addressing & Routing
LAN facing router's IP address on the MGMT_VLAN
/interface vlan add interface=BR1 name=MGMT_VLAN vlan-id=99
/ip address add address=192.168.99.1/24 interface=MGMT_VLANDNS server, set to cache for LAN
/ip dns set allow-remote-requests=yes servers="8.8.8.8"
WAN facing port with IP Address provided by ISP
/ip address add interface=ether1 address=192.168.188.222/24 network=192.168.188.0
router's gateway provided by ISP
/ip route add distance=1 gateway=192.168.188.1
IP Services
CCTV VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=CCTV_VLAN vlan-id=1
/ip address add interface=CCTV_VLAN address=192.168.0.1/24
/ip pool add name=CCTV_POOL ranges=192.168.0.100-192.168.0.254
/ip dhcp-server add address-pool=CCTV_POOL interface=CCTV_VLAN name=CCTV_DHCP disabled=no
/ip dhcp-server network add address=192.168.0.0/24 dns-server=8.8.8.8 gateway=192.168.0.1WiFi VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=WiFi_VLAN vlan-id=100
/ip address add interface=WiFI_VLAN address=192.168.100.1/24
/ip pool add name=WiFI_POOL ranges=192.168.100.100-192.168.100.254
/ip dhcp-server add address-pool=WiFi_POOL interface=WiFi_VLAN name=WiFi_DHCP disabled=no
/ip dhcp-server network add address=192.168.100.0/24 dns-server=8.8.8.8 gateway=192.168.100.1PPoE VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=PPoE_VLAN vlan-id=88
/ip address add interface=PPoE_VLAN address=192.168.88.1/24
/ip pool add name=PPoE_POOL ranges=192.168.88.100-192.168.88.254
/ip dhcp-server add address-pool=PPoE_POOL interface=PPoE_VLAN name=PPoE_DHCP disabled=yes
/ip dhcp-server network add address=192.168.88.0/24 dns-server=8.8.8.8 gateway=192.168.88.1Optional: Create a DHCP instance for MGMT_VLAN. Convenience feature for an admin.
/ip pool add name=MGMT_POOL ranges=192.168.99.10-192.168.99.254
/ip dhcp-server add address-pool=MGMT_POOL interface=MGMT_VLAN name=MGMT_DHCP disabled=no
/ip dhcp-server network add address=192.168.99.0/24 dns-server=8.8.8.8 gateway=192.168.99.1#######################################
Firewalling & NAT
A good firewall for WAN. Up to you
about how you want LAN to behave.
Use MikroTik's "list" feature for easy rule matchmaking.
/interface list add name=WAN
/interface list add name=VLAN
/interface list add name=BASE/interface list member
add interface=ether1 list=WAN
add interface=MGMT_VLAN list=VLAN
add interface=CCTV_VLAN list=VLAN
add interface=PPoE_VLAN list=VLAN
add interface=MGMT_VLAN list=BASEVLAN aware firewall. Order is important.
INPUT CHAIN
add chain=input action=accept connection-state=established,related comment="Allow Estab & Related"Allow VLANs to access router services like DNS, Winbox. Naturally, you SHOULD make it more granular.
add chain=input action=accept in-interface-list=VLAN comment="Allow VLAN"
Allow MGMT_VLAN full access to the device for Winbox, etc.
add chain=input action=accept in-interface=MGMT_VLAN comment="Allow MGMT_VLAN Full Access"
add chain=input action=drop comment="Drop"
FORWARD CHAIN
add chain=forward action=accept connection-state=established,related comment="Allow Estab & Related"Allow all VLANs to access the Internet only, NOT each other
add chain=forward action=accept connection-state=new in-interface-list=VLAN out-interface-list=WAN comment="VLAN Internet Access only"
add chain=forward action=drop comment="Drop"
NAT
/ip firewall nat add chain=srcnat action=masquerade out-interface-list=WAN comment="Default masquerade"#######################################
VLAN Security
Only allow packets with tags over the Trunk Ports
#set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether2]
#set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether3]
#set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether4]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether5]#######################################
MAC Server settings
Ensure only visibility and availability from MGMT_VLAN, the MGMT network
/ip neighbor discovery-settings set discover-interface-list=BASE
/tool mac-server mac-winbox set allowed-interface-list=BASE
/tool mac-server set allowed-interface-list=BASE#######################################
Turn on VLAN mode
/interface bridge set BR1 vlan-filtering=yes
Some output from my router:
[admin@Router] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 I ether5 BR1 yes 1 0x80 10 10 none
1 I ether2 BR1 yes 88 0x80 10 10 none
2 ether3 BR1 yes 99 0x80 10 10 none
3 I ether4 BR1 yes 100 0x80 10 10 none
[admin@Router] > /interface bridge vlan print
Flags: X - disabled, D - dynamic
BRIDGE VLAN-IDS CURRENT-TAGGED CURRENT-UNTAGGED
0 BR1 1 BR1
1 BR1 88 BR1
2 BR1 99 BR1 ether3
3 BR1 100 BR1
[admin@Router] > /interface bridge print
0 R name="BR1" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:B4:9A:01 protocol-mode=none fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m vlan-filtering=yes ether-type=0x8100 pvid=1
frame-types=admit-all ingress-filtering=no dhcp-snooping=no
[admin@Router] >
I know that I failed on so basic things ... but how to fix this config, Hope someone will be able to guide me :)
Regards
Slawek
