router with web-proxy enabled crashes
a few days ago i enabled the web-proxy on a mt router with fairly high traffic. since then the system has crashed completely (hardware reset necessary) every day and the log has often this error line:
Web-proxy error while running: squid was killed with signal11, restarting
system is a p3 pc with 4 intel-NICs, 128 mbyte RAM, router os 2.8.22 on CF and a 10 gbyte IDE-hd as cache drive. cpu load is usually below 20 percent. the proxy is running as transparent proxy with the usual dst-nat rules in place. the router is running mainly as PPPoE-server and has OSPF enabled.
anyone with similar problems or an idea?
tia.
matthias
The web proxy is not stable in my opinion. I have started turning it off in most of my machines because I just can’t trust it.
I upgrade to 2.8.22 and the web proxy is slow. If i stop it the navigation is fast, but if i enabled it is turn slow
M.
Try increasing RAM, reducing diskspace used by cache, making sure drive doesn’t have errors.
Try limiting Cache Size in the HDD to 2Gb or less…
Regards
as u mentioned her u have 10GB HDD then at least 16 MB of required per GB either u increase RAM or decrease cache space
