routerboard 1000 dead after reset c229 configuration
routerboard 1000 dead after reset c229 configuration.
It cant even boot pass 1st kernel router layer. Anyone encounter that before??
Provide us with console output you get from RouterBOARD 1000.
Have you tried to reinstall RouterBOARD by Netinstall?
Hi all.
We have exactly the same problem with one of us RB1000. After a reboot (order in the Winbox to restart the system), the RB1000 is not responding.
We use the console to connect it, but it doesn´t show anything. We can´t connect to the Boot loader because it doesn´t show.
Someone had the same problem and could help us?
Thanks in advance.
i have a similar problem on a routerboard. i need to perform two reboot in order to have properly running rb/1000. in console log a have some messages regardin kernel crash, i will post i next days.
a netinstall will fix all.
Exakt the same problem. Any Ideas?
I have a other routerboard in the same local network. Can i try to boot it from the other routerboard?
