Routerboard 1100 Webfig
Hello All,
I have a routerboard 1100. This had OS 4.11 by default.
I upgraded the routerboard to OS 6.10 from 4.11
Now when i go to the web interface I see the old Interface pre-Webfig era but with broken images. Is there any way I can make the new Web interface the default web interface.
Please advice.
many thanks for the assistance.
1 - Don’t use webfig. It will break things in strange ways.
2 - If you must use webfig, try:
/system routerboard upgrade
/file remove [find]
/system reset-configuration no-defaults=yes
which should ensure you’re on the latest firmware (not ROS version), that all the old files are removed (care, make sure to back any files you may need up) and that everything in ROS is reset to base configuration (again, make sure you export anything you want to keep).
