Routerboard 1100AH static IP - does neither ping nor access
I have a new routerboard 1100AH with RouterOS 5.8
I can access it over serial, then i did run:
/ip address remove 0 #to remove the default IP
/ip address add address=91.227.204.205/24 interface=ether1 comment=“default configuration” #to add my new IP
#this should be correct, ether1 is connected to a switch connected to a cisco router which is the gateway for this IP space (.1 is the gateway)
#we do not have DHCP as this is a datacenter enviroment
/ip firewall nat print #is empty
I can however not access it by the IP, neither by Web nor Winbox or SSH and telnet - it does not even ping.
However, the Board seems to be aware that it got the IP, because inside the same vlan it replies to arping with its MAC address of ether1 for this IP once i run the add command
So yes, i am kinda lost now - any help? :frowning:
Thanks,
William
Make sure you are plugged into the correct Ethernet port. If you have a cable plugged into the Ethernet port, you should be able to run /interface print and if the interface is up and running, it will have an R besides it.
Yes, as it arpings it must be connected right - ether1 also shows the R.
Still… no access at all
Are you plugged directly into Ether1 with your computer, or going through a switch? You mention VLANs, so a clearer picture of your network would be useful to isolate the issue.
Ehter1 is plugged into the lan that routes the IP that is assigned to ehter1 - It is a flat L2 network, Gateway is on .1, Netmask is /24 / .0.
So technically this setup should be correct, but it does not seem to work at all.
Like I said, provide a network diagram, and preferably the output of “/export compact” and people can take a look at it. Without enough information, at best we are just shooting in the dark.
Well:
Uplink A Uplink B
Cisco BGP AS57169
24Port Switch in flat Layer2 network
Routerboard ether1
The RouterOS on this one cannot do compact export it seems, so here is the complete one:
# jan/05/1970 22:04:57 by RouterOS 5.8
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 mac-address=00:0C:42:EB:B6:4C mtu=1500 \
    name=ether12 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 mac-address=00:0C:42:EB:B6:4D mtu=1500 \
    name=ether13 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:41 master-port=none mtu=1500 name=ether1 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:42 master-port=none mtu=1500 name=ether2 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:43 master-port=none mtu=1500 name=ether3 speed=100Mbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:44 master-port=none mtu=1500 name=ether4 speed=100Mbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:45 master-port=none mtu=1500 name=ether5 speed=100Mbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:46 master-port=none mtu=1500 name=ether6 speed=100Mbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:47 master-port=none mtu=1500 name=ether7 speed=100Mbps
set 9 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:48 master-port=none mtu=1500 name=ether8 speed=100Mbps
set 10 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:49 master-port=none mtu=1500 name=ether9 speed=100Mbps
set 11 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:EB:B6:4A master-port=none mtu=1500 name=ether10 speed=100Mbps
set 12 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 mac-address=00:0C:42:EB:B6:4B mtu=1500 \
    name=ether11 speed=100Mbps
/interface ethernet switch
set switch2 mirror-source=none mirror-target=none name=switch2
set switch1 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 \
    login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m \
    transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=default use-encryption=default use-mpls=\
    default use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=default use-compression=default \
    use-encryption=yes use-mpls=default use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 \
    red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set only-hardware-queue kind=none name=only-hardware-queue
set multi-queue-ethernet-default kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no ignore-as-path-len=no name=default out-filter="" \
    redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=\
    no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in metric-bgp=auto metric-connected=20 \
    metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=\
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/snmp
set contact="" enabled=no engine-id="" location="" trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" \
    encryption-protocol=DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto \
    target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=5s boot-device=nand-only boot-protocol=bootp cpu-frequency=1066MHz \
    enable-jumper-reset=yes enter-setup-on=any-key force-backup-booter=no memory-data-rate=533DDR silent-boot=no
/user group
set read name=read policy=\
    local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,!ftp,!write,!policy skin=default
set write name=write policy=\
    local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,!ftp,!policy skin=default
set full name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api \
    skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set ether1 vlan-mode=disabled
set ether2 vlan-mode=disabled
set ether3 vlan-mode=disabled
set ether4 vlan-mode=disabled
set ether5 vlan-mode=disabled
set ether6 vlan-mode=disabled
set ether7 vlan-mode=disabled
set ether8 vlan-mode=disabled
set ether9 vlan-mode=disabled
set ether10 vlan-mode=disabled
set switch1_cpu vlan-mode=disabled
set switch2_cpu vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 \
    mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 \
    mac-address=FE:3D:84:C3:0D:5C max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 \
    max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no keepalive-timeout=60 \
    max-mru=1500 max-mtu=1500 mrru=disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=91.227.204.205/24 comment="default configuration" disabled=no interface=ether1 network=91.227.204.0
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
add address=91.227.204.205 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
    tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether12 disabled=no
set ether13 disabled=no
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set ether6 disabled=no
set ether7 disabled=no
set ether8 disabled=no
set ether9 disabled=no
set ether10 disabled=no
set ether11 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=\
    none max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 \
    transport-address=0.0.0.0 use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether12 queue=only-hardware-queue
set ether13 queue=only-hardware-queue
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set ether6 queue=only-hardware-queue
set ether7 queue=only-hardware-queue
set ether8 queue=only-hardware-queue
set ether9 queue=only-hardware-queue
set ether10 queue=only-hardware-queue
set ether11 queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway \
    origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 \
    metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
set 9 cpu=auto
set 10 cpu=auto
set 11 cpu=auto
set 12 cpu=auto
set 13 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set (unknown) disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
    only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Where are you trying to ping the router from? From within the same subnet, or on the other side of the Cisco router? Currently it does not have a default route, so it can only reply to pings that are from the same subnet as itself. Without a default route it doesn’t know how to reach any other subnets.
