Routerboard 1100AH
How do I setup multiple wan ip
Under IP address should I just type xx.68.129.224/25
and if yes. Where should I set the rest of the ip number ??
thanks
Just add multiple IP addresses on your WAN interface in “/ip address”
destnat is only working on the first ip
i have added the following in / ip addresses
xx.68.129.224/25
xx.68.129.225/25
xx.68.129.226/25
xx.68.129.227/25
I can only nat to the first ip
post your “export compact” from “/ip firewall nat” and “/ip firewall filter”
found the “bug”
