Routerboard 112 and routing problem
Hello Everybody.
I’m almost new with Mikrotik and Routerboards so… thanx in advance for patience and understanding…
I’m trying to configure RB112 with one mini PCI WI-FI card as Station and still have problems . First try it was few days ago and then i’ve tried to make transparent bridge… after configuration it looks good I mean ping goes to both direction ( to local and to public ip addresses) but didn’t goes from local computer through MT (bridge) to public network… So i decide to leave such configs and I’ve tried to setup normal router with WAN on wlan1 and LAN on ether1 interface so I’ve made simple setup with this two interfaces but when I’ve tried to add static route with dst-address 0.0.0.0/0 and default gateway 192.168.0.1 it appear on the list but with A ( active) and with unknown interface … so I’m stack :frowning: any advice very welcome… one more thing what I found is that in Winbox >> Drivers there is only wlan card on the list no any ether card there ( in my opinion should be) and second thing is that in System >> Resources >> PCI device 00:00:0 ( which should be ether card probably ) is unknown without any IRQ assigned… Thanx
