Mine are all in the field; I can’t look at the usage at the moment. They do run RouterOS quite well. These have a place in the network - at the end. They’ll run out of cpu before ram. Cool little boards.
Edit —> Had a spare in the garage. It has 6.1 meg free setup as a CPE.
The paging functions in the Linux kernel will do this if it runs out of pageable memory to page around. The cpu load would also be reduced if there was more available memory (or a swap file, hehe).
You could put a 1 ghz cpu in there with that amount of memory and it wouldn’t exactly dazzle you with performance when so much cpu time is spent in the paging system.
