Routerboard 112
This Routerboard will support 2 x Mini-PCI card can anyone recommend a Wireless N card which will work well with it?
Thanks,
Aaron
new RouterOS doesn’t even work on this model.
why not get a much chepaer but newer model?
I wanted something with dual WiFi so it could be used as a access point and station at the same time, could you recommend something?
https://mikrotik.com/product/rbm33g
Or, if a low-end solution is adequate, complete solution for the same price: hAP ac lite (available in mini-tower enclosure as well). I’m using a pair in one of my installations, 5Ghz radio running nstreme as bridge between the two and 2.4GHz for 802.11 clients.
