RouterBoard 133C
Hi I have a routerBoard 133C, I did a reset on the board so it has its default setting, I log in using winbox and its default IP 192.168.88.1.Then I go strait to the interface tab and enable the wireless interface, after about 3 sec I get an error “Router has disconnected” and the board restarts. When I login again the wireless interface is still disabled. The reset jumper is not on. My mini PCI card that is connected is a RouterBoard R52 R1. Please advise what Im doing wrong, and if my board is broken or something. It did work previously but after the reset I cant seem to configure the settings.
Try to upgrade/downgrade routeros.
rb113C has limited resources. if you are using a newer version of RouterOS, like 5.x then reinstall router with minimal set of packages, like system and wireless. Then try again.
