RouterBOARD 133C3
Dear Friends
i have two boards of this kind the RouterBOARD 133C3 i have some question’s about them can i power them up through poe they only have one lan port if i can then how can i feed in data to the board does this board RouterBOARD 133C3 use 12 volts or 5 volts because i used output: +5.1v= 2.0A would that burn my board can some one tell me the exact power voltage’s for the board so don t end up low powering it or burning it can i access the board without a wireless card on it if yes can you please tell me the deafult ip if no after i put a 2.4ghz card what would be the deafult ip and do i login through winbox?
Yes you can - board supports passive poe.
Your poe adaptor should have a ‘power+data’ port as well as a ‘data only’ port. Connect your pc to the data only port and your RB to the power+data port.
Supports 9-30volts. I recommend at leats 12volts - up to 18v if you’ have a long cable run.
Yes you can, as alluded to above.
After you put a wireless card, by default the wlan interface will be disabled. With or without your wireless card installed, using winbox for initial config, you don’t need an ip - browse for your RB and use mac address; defualt login=admin leave password field blank. Just for information, default ip is usually 192.168.88.1 on ether1 (lan port).
I think RB133C didn’t have this default IP, but I could be wrong
well i can use a 12 volt adapter one two i have a poe that has 12 volt in put and removes 48v that i can t use and u mean i shuld tke the mac of the board and put enter in winbox then it will log me in to the board i have 2 sector anntena’s and 4 mitrotik boards two big two small i have a vsat pumping in internet i want to pump it into the mitrotik boards and broacast through my sector anntena’s and have sum omin anntena’s to 2.4ghz i wana make a small network but need help on how to config on the winbox ?
i have just downloaded a pdf file of MikroTik RouterOS™ v3.0
Reference Manual
is this a operating system i have to install and use as a server or is it just a reference manual of winbox ? can i run all my anntenna’s through winbox without having a server and making winbox do everything bandwith control firewall user name passwords for clients if a user goes over his limit putting him bck to his limit like if a user is using alot of bandwith his given 10 kbps and he uses 20 bringing him bck to 10 is tht possible also can i remotely login to all my routers? and check who’s logged on to which ap what time etc
dafault IP is 192.168.88.1
Just open winbox and click search button, and connect it by IP or MAC address.
