I just bought 2 outdoor 230 routerboards direct from mikrotik. The CPU usage is always 100%, even if I disable all connections but the ethernet I am connecting through. I bought 2 boxes, and both do the same thing. Is there a bug in the CPU reading? I am reading it via winbox.
What version of MT you have?
We had that problem on RB230 with version 2.8.21 but upgrading solved the problem…
Cheers…
I have 2.8.24
I will upgrade to the latest and see what happens.
so upgrading to 2.8.25 made the CPU read normally, thanks!
