RouterBOARD 3011UiAS v.6.47.1 and HUAWEI e8372h-320
Hi All! I inserted the HUAWEI e8372p-320 into the router and I see this picture, every 2 seconds a link up link down. Router firmware version 6.47.1, WTF???!!!
Don’t swear.
On a PC does it show up as a storage USB drive with software in? If it does, you need to reflash it to ‘Stick’ mode which I found impossible.
Upgrading to ROS7 beta might also help. It works for a E3372h-320 in HiLink mode anyway, which behaves the same under ROS6.
I wish I could turn mine into stick mode but it never worked and I wept.
I can confirm that with the ROS 7.1beta2 Huawei E8372h-320 modem is working fine on RB951Ui-2HnD.
Shame it’s beta and not suitable for production. How I weep
I got my modem today and immediately got issue with the link going up and down.
But my modem is a HiLink version and it does not show as a USB drive on a PC. It is working as a LAN modem connected to a PC USB port and as a stand-alone wlan AP plugged in a USB charger.
Yes, beta is not recommended for production because it messed up my routes. I tried using only LTE package from ROS 7 and other packages from 6.48, but the link was going up and down nevertheless.
Till this is implemented in more stable version, I will be without automatic LTE backup.
has the problem been resolved?
No, not in 6.48.2 I’m afraid.
I had the same problem with a hap ac2 and a HUAWEI e8372h and I can confirm that upgrading to rOS7 solved it.
Thank you
Hi, are you able to set APN, PIN and other parameters with v7? I upgrade my RB951G-2HND to 7.1beta6 and interface is not flapping now but I can’t set that parameters to the lte interface.
