Routerboard 411/411r not booting
Hello everyone
I have a 411/411r r52 routerboard, that all of a sudden stopped booting or maybe its something else i don’t know, what happens is when i try to turn it on, all the lights on the board stays on and nothing else happens (Blue light led and the led on top of it next to ether port, 4 led lights out of 5 next to serial port “1st one next to serial is off, the rest of 4 are on”) . no beeps, no blinks, ether port lights are off.
I was working on it a day before and it didn’t seem like it have any problem. Is it a hardware or system failure?
I appreciate the help
Try: different power source, if that doesn’t fix it, try a netinstall.
It may be a hardware problem, have you visually inspected the PCB for any obvious damage?
Hello pukkita
I did try a different power source (changed adapter and electric plug) as thats the 1st thing i suspected.
Then i did a visual inspect, nothing look abnormal.
I didn’t try the netinstall as am new to this, so i will look up the steps and try to see what will happen.
Thanks for ur help
