Hello guys i have RB411, and when i turn it on the lights are working, ehernet lights also, i tryed to factory reset, but i still cant view my card in Winbox
This is your first and only RouterBoard or can you successfully log into other RouterBoards with Winbox and the same computer?
Tom
I have another, and i can log in that card. what is the problem?
if your routerboard is the new one and it is the first time log in , You
can log in by ip 192.168.88.1 (Mikrotik default ip for mikrotik
routerboards).
I cant find my card i connected everything. Nothing form ip pinging, nothing from winbox. Thanks
do u have serial cable to see thats happening? if u have try to connect to the serial port and see whats going on.
