routerboard 433 and r52n
Hi guys,
I have a routerboard 433 with routerOS v4.0beta3 (upgraded from v3.10) and a minipci radio R52n
I dont know how to see the radio. when I go with winbox to interfaces I only see ehter1 2 and 3 but no wlan1
any suggestions??
thanks for any help
Did you upgrade your license? Check out: http://wiki.mikrotik.com/wiki/802.11n_Setup_Guide
Good luck,
-tp
To use “n” you must update your ROS license. In winbox, go to system -->license and click on “Update License Key” botton. Reboot the router and the R52n card should appear in wireless interface.
Thanks guys, that did the trick.
working now. much appreciated!
