RouterBoard 433AH Dead or What?
Hello All !
Today i got the new item what to test RouterBoard 433AH it was brand new and worked.
I turn off atfer tests
On user interface click on button shutdown after ~25 30 seconds plug out of electricity.
And after 3 hours when i want to continue tests router no answer :frowning:
Router dont give any packets activity on my pc’s nic (test on 2 pc), 0 received packets from router.
I turn on router i first flash blue lamp, green after ~1 minute it beeps to 2times and that all.
Latviski:
Tika paņemts routeris testam RouterBoard 433AH kurš pirms tam strādāja,bija darba kārtībā.
Routeris tika ieslēgts lai apskatītu kādi ir useri uztaisīti un viss.
Pēc 3 stundām tika nolemts ķerties klāt un iztestēt, bet routeris vispār neizrāda uz nekādas dzīvības pazīmes.
Kad tiek routeris ieslēgts pie elektrības tam nomirgo visas lampiņas, tad iepīkstas pēc brīža ir divi pīkstieni. Deg POE ports ar kuru ir pieslēgta barošana, un 1 ports pie kura ir pieslēgts PC.
Winbox discovery by MAC doesn’t work either??? Netinstall!
AFAIK 2 beeps mean it has booted up normally.
Latviski:
Winbox pēc MAC adreses arī neatrod? Tātad Netinstall.
Cik atceros 2 pīkstieni nozīmē ka ir iebootojies normāli.
yes, two beeps means RouterOS is loaded fine. Must be a connection issue. Maybe you disabled the interfaces or something like that?
Needs console cable anyway :sunglasses:
yes
