The RB433AH is a more powerful version of the standard RB433. The 128MB DDR will be capable of supporting new RouterOS features coming. The microSD slot supports an additional memory card that can be used for a Dude database and other features to be announced in during Spring ‘08.
The 680MHz Atheros MIPs 24K CPU, that can be overclocked to 800MHz, with a 64KB/32KB instruction/data cache is probably the fastest CPU
used in low cost wireless access points. The three Ethernets and mpci slots give you ample data interfaces to put the big CPU power to work.
The RB433 and RB433AH replace the RB133 and RB333 positions of our product line.
Sounds great!
When do you expect it to be available at distributors in the US?
George
This board sounds awesome !
I would have given it a different code though e.g. RB468 or something so there is a clear differentiation.
OK normis…here I am! So if I wanted one of these also, “when” and “how much”?
ADD: If I could add a vote for a power supply input (not PoE) of < 11.5vdc? My low voltage disconnects are set at 11.5 volts.
specification
Thanks for the specs. That 10..28v falls within limits for me.
