Routerboard 435G Dimensions ??
Hello:
The routerboard 435G dimensions appear to be 105mm x 105mm, on the datasheet specifications, this board should eb suqared, but in the images it does not pretend totally square. Some explanation of this?
Anyone with real size please?
Thanks in advance,
Joaquin
(from serial connector to miniPCI clip) 170mm * 105mm
keep in mind - You may need extra space if You plan to use miniPCI slots
I was under the impression that it was the same dimensions as the RB433 and the RB433AH.
