Routerboard 450G performance
Dear community,
Are there numbers about the expected LAN - > WAN and WAN → LAN throughput (NATTED)? I’m looking for at least 100 megabit throughput (well in both directions if fiber to the home takes off).
Also, can the switch (grouping 4 ports together) be configured for wire speed? At this moment I have a Draytek 2130 router and I’ve used both IPERF and Ixia and my I was able to conclude my LAN swiching speed was about 100 megabyte/second.
Best regards,
Jeroen
If interfaces are switched then you can get full wire speed (1GBps).
