I installed it, I think. It was seen in 5.23, but it wouldn’t format. So I thought update to the latest RC10 of 6.0 just in case, and now it’s not listed at all or I can’t find it.
It’s not clear to me from the Wiki where it is supposed to show up. I inserted the card the only way it would slide in easily and pushed it until it stopped.
Any suggestions/things I can provide to help see what I’m doing wrong? Or is this just a card that doesn’t work?
If it hasn’t come up after the upgrade try shutting down the mikrotik and then pull out the power. Then plug it back in and see if it appears. If so then try a reboot in software and see if it disappears.
This is a known problem if it does disappear.
I have had very good luck myself with the Ultra class 10 cards (Strontium 16GB class 10 / Ultra 1) and with the class 2 speed cards.
It seems ones in the middle (class 4, 6 especially) have a problem on soft reboot but they do come live after a full power cycle.
You can try other cards or make sure that you never have it soft reboot
