I've got a problem with RouterBOARD 493G.
I just wanted to upgrade packages from version 5.14 to 6.15 and after reboot i have found this issue via serial port:
RouterBOOT booter 3.18
RouterBoard 493G
CPU frequency: 680 MHz
Memory size: 256 MiB
NAND size: 128 MiB
Boot configuration reset, applying defaults
writing settings to flash... OK
Press any key within 2 seconds to enter setup..
trying bootp protocol............... failed
kernel loading failed
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
failed to open /dev/flash: No such file or directory
Resetting system configuration...
Generating SSH DSA key...
Starting services...
Demo license expired!
Please reinstall the router.
connect failed (errno=2)
After reboot i did "reset booter configuration" and from this point the Routerboard's green LED diods (LD41-44) are lighting and device seems to be dead.
I've got here 3 more devices with similar issues.
Do you have any idea whats wrong and how to fix it?
Thanks.
RouterBoard 493G
NAND size: 128 MiB
Boot configuration CRC error, applying defaults
RouterBOOT-3.18
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
f - cpu frequency
r - reset booter configuration
e - format nand
w - repartition nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
t - do memory testing
x - exit setup
your choice: r - reset booter configuration
writing settings to flash..writing settings to flash... OK
RouterBoard 493G
NAND size: 128 MiB
Starting...
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000000 d00bc000 cfc04d40
$ 4 : d00bc800 00000000 00000000 80006000
$ 8 : 00000000 c0236950 c12025b4 c11e9b54
$12 : c12025bc c12025c0 00000000 00000000
$16 : cf510000 cf510000 cf510000 cf510000
$20 : cf510000 cf510000 00000000 cf510000
$24 : 00000002 c011332c
$28 : cf4b2000 cf4b3e00 cf510000 cf508e70
Hi : 0000c138
Lo : 00000022
epc : cf508e70 init_module+0x514/0x994 [flash@0xcf508000]
Not tainted
ra : cf508e70 init_module+0x514/0x994 [flash@0xcf508000]
Status: 1000c603 KERNEL EXL IE
Cause : 00800008
BadVA : 00000000
PrId : 00019374 (MIPS 24Kc)
Process insmod (pid: 30, threadinfo=cf4b2000, task=cfcd19e0, tls=77bc4460)
Stack : 00000124 d1200000 1fc00000 cf510000 31120006 cf50d4e8 00000000 cf510000
cf50d4a0 cf50895c 00000000 c0400000 c0400000 00000018 00000028 c015586c
00000124 c0101624 c0158074 cfc04e00 0000000a 00000000 cf50d4e8 c01972e0
cf50d4a0 c01421d0 00000000 cf50d4a0 cff7ce00 c03c0000 c03c0000 c03c0000
00000018 c01578c8 cf845b38 77bb2000 00000000 00000000 cf50d4ac 00000000
Call Trace:
[] init_module+0x514/0x994 [flash@0xcf508000]
[] do_one_initcall+0xf4/0x1c0
Code: 24060800 0c08da18 ae82d614 <8ec50000> 3c026472 24426148 14a20007 3c15 cf51 3c17cf51
---[ end trace 9705938b71055c24 ]---
NET: Registered protocol family 1
NET: Registered protocol family 17
logring: default buf size:4096, console_loglevel:15
console [logring0] enabled
