Currently have 1xSR2 and 1xSR5 card on RB532, as well as a compex WLM54AG on the daughterboard 564. I need to get another radio on this setup… Reading forums suggests that going on max power of the verious radios (SR cards each consuming 4.3W), it looks it would be a bad idea to try another compex WLM54AG on the same daughterboard… which means it would be 1x SR2, 1x SR5, 2 x WLM54AG. If not, how bout removing the SR2 and replacing it with a WLM54AG… so 1 x SR5, 3 x WLM54AG
Its a pretty important basestation, i experimented once with adding a WLM54AG with the SR2 and SR5 cards. I’m not sure if adding another WLM card will be worth it. This basestation serves some very important clients.
Thanks to all in advance
Jith
