routerboard 532 netinstall problem
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:06:13:80
software-id: HPDR-3TT
key: xxxxxxx
Waiting for installation server…
Found server at 00:13:CE:83:F5:3E
Formatting disk…
FATAL ERROR: bad network connection
Press ENTER to reboot
Can You help me please?
how connect to console ???
me connect but i dont now how reboot to enter the boot options
say only pres ctr -x or pres a or b or q ?
connect from windows terminal?
I hve seen this prob with the RB500 Series boards..
It is NOT the RouterBoard (the screen you show looks more like a intel install…)
The cause (for me) wan the NIC on the “installation server”.
Try another NIC on the installarion source..
I wan using an onboard intel based NIC on a Compaq M700 and it would time out when the RB500 would drop its connection for a split second durring the installation, the M700 NIC would freak nad the installation would fail..
The fix was to install a Xircom CE3 NIC in the PC-Card slot and install via a X-Over cable..
WORKS GREAT LASTS LONG TIME !!!
So try using another NIC in your install server and you will have better results..
Best of luck !!
Craig
