routerboard 711
can anyone give a bandwidth test with 2 pieces of new routerboard 711
I’m doing some testing now. This is a NV2 v. 5 RC1
711A AP mmcx
711 for CPE mmcx
-56 sig
1 mile shot.
Default settings nv2 settings for N
avg ping 500 bytes = 9MS
Achieved Data Rates=54M/54M
TCP
TX=33M
RX=32M
UDP
TX=50M
RX=51M
Enabled extension channel
Achieved Data Rates=135M/135M
avg ping 500 bytes = 10MS
TCP
TX=38M
RX=35M
UDP
TX=110M
RX=105M
Tried 10mhz channel and AP goes crazy and only accessible via mac-telnet. CPE will not connect to it even though it is set to 10mhz
I would like to see some other people sound off with what they are getting.
This is the other tests:
5GHz only 5GHz-only- n 5GHz with nstreme 5GHz-n with nstreme
UDP TCP UDP TCP UDP TCP UDP TCP
29 23 30 24 42 36 54 37Mbps
