RouterBoard 750 GL Script Error
I have just purchased the Router Boad 750 GL. I have applied your all script . But device gave me some error message. Can you tell me what is this error.
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 5.21 (c) 1999-2012 http://www.mikrotik.com/
[admin@MikroTik] > /IP ADRESS
expected command name (line 1 column 2)
[admin@MikroTik] > IP ADRESS
expected command name (line 1 column 1)
[admin@MikroTik] > /ip address
[admin@MikroTik] /ip address> add address=192.168.0.1/24 network=192.168.0.0 broad
cast=192.168.0.255 interface=Localal
[admin@MikroTik] /ip address> add address=192.168.1.2/24 network=192.168.1.0 broad
cast=192.168.1.255 interface=WAN1N1
[admin@MikroTik] /ip address> add address=192.168.2.2/24 network=192.168.2.0 broad
cast=192.168.2.255 interface=WAN2N2
[admin@MikroTik] /ip address> add address=192.168.3.2/24 network=192.168.3.0 broad
cast=192.168.3.255 interface=WAN3N3
[admin@MikroTik] /ip address> add address=192.168.4.2/24 network=192.168.4.0 broad
cast=192.168.4.255 interface=WAN4N4
[admin@MikroTik] /ip address> /ip firewall mangle
[admin@MikroTik] /ip firewall mangle> add dd chain=input in-interface=WAN1 action=
mark-connection new-connection-mark=WAN1_connnn
expected end of command (line 1 column 5)
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN2 action
=mark-connection new-connection-mark=WAN2_connnn
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN3 action
=mark-connection new-connection-mark=WAN3_connnn
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN4 action
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN4 action=
[admin@MikroTik] /ip firewall mangle>> add chain=output connection-mark=WAN1_conn a
ction=mark-routing new-routing-mark=to_WAN1
[admin@MikroTik] /ip firewall mangle> add chain=output connection-mark=WAN2_conn ac
tion=mark-routing new-routing-mark=to_WAN2
[admin@MikroTik] /ip firewall mangle> add chain=output connection-mark=WAN3_conn ac
tion=mark-routing new-routing-mark=to_WAN3
[admin@MikroTik] /ip firewall mangle> add chain=output connection-mark=WAN4_conn ac
tion=mark-routing new-routing-mark=to_WAN4
[admin@MikroTik] /ip firewall mangle> add dd chain=prerouting dst-address=192.168.1
.0/24 action=accept in-interface=Local
[admin@MikroTik] /ip firewall mangle>> add dd chain=prerouting dst-address=192.168.
2.0/24 action=accept in-interface=Local
3.0/24 action=accept in-interface=Local
4.0/24 action=accept in-interface=Local
[admin@MikroTik] /ip firewall mangle>> add dd chain=prerouting dst-address-type=!lo
cal in-interface=Local per-connection-classifier=both-addresses-and-ports:4/0 actio
n=mark-connection new-connection-mark=WAN1_conn passthrough=yes
cal in-interface=Local per-connection-classifier=both-addresses-and-ports:4/1 actio
n=mark-connection new-connection-mark=WAN2_conn passthrough=yes
cal in-interface=Local per-connection-classifier=both-addresses-and-ports:4/2 actio
n=mark-connection new-connection-mark=WAN3_conn passthrough=yes
cal in-interface=Local per-connection-classifier=both-addresses-and-ports:4/3 actio
n=mark-connection new-connection-mark=WAN4_conn passthrough=yes
[admin@MikroTik] /ip firewall mangle>> add dd chain=prerouting connection-mark=WAN1
_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
[admin@MikroTik] /ip firewall mangle>> add dd chain=prerouting connection-mark=WAN2
_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
[admin@MikroTik] /ip firewall mangle>> add dd chain=prerouting connection-mark=WAN3
_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN3
[admin@MikroTik] /ip firewall mangle>> add dd chain=prerouting connection-mark=WAN4
_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN4
[admin@MikroTik] /ip firewall mangle>> /ip route
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.1.1 routi
ng-mark=to_WAN1 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.2.1 routi
ng-mark=to_WAN2 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.3.1 routi
ng-mark=to_WAN3 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.4.1 routi
ng-mark=to_WAN4 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.1.1 dista
nce=1 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.2.1 dista
nce=2 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.3.1 dista
nce=3 check-gateway=ping
[admin@MikroTik] /ip route>> add dd dst-address=0.0.0.0/0 gateway=192.168.4.1 dista
nce=4 check-gateway=ping
[admin@MikroTik] /ip route>> /ip firewall nat
[admin@MikroTik] /ip firewall nat>> add dd chain=srcnat out-interface=WAN1 action=m
asquerade
[admin@MikroTik] /ip firewall nat>> add dd chain=srcnat out-interface=WAN2 action=m
asquerade
[admin@MikroTik] /ip firewall nat>> add dd chain=srcnat out-interface=WAN3 action=m
asquerade
[admin@MikroTik] /ip firewall nat>> add dd chain=srcnat out-interface=WAN4 action=m
asquerade
[admin@MikroTik] /ip firewall nat>> /ip address
[admin@MikroTik] /ip address>>
[admin@MikroTik] /ip address>> add disabled=d address=192.168.0.1/24 network=192.16
8.0.0 broadcast=192.168.0.255 interface=Local
syntax error (line 1 column 14)
[admin@MikroTik] /ip address>> add disabled=d address=192.168.1.2/24 network=192.16
8.1.0 broadcast=192.168.1.255 interface=WAN1
[admin@MikroTik] /ip address>> add disabled=d address=192.168.2.2/24 network=192.16
8.2.0 broadcast=192.168.2.255 interface=WAN2
[admin@MikroTik] /ip address>> add disabled=d address=192.168.3.2/24 network=192.16
8.3.0 broadcast=192.168.3.255 interface=WAN3
[admin@MikroTik] /ip address>> add disabled=d address=192.168.4.2/24 network=192.16
8.4.0 broadcast=192.168.4.255 interface=WAN4
[admin@MikroTik] /ip address>> /ip firewall mangle
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN1 action=
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN2 action=
[admin@MikroTik] /ip firewall mangle>> add dd chain=input in-interface=WAN3 action=
[admin@MikroTik] /ip firewall mangle>> add dd chain=output connection-mark=WAN1_con
n action=mark-routing new-routing-mark=to_WAN1
[admin@MikroTik] /ip firewall mangle>> add dd chain=output connection-mark=WAN2_con
n action=mark-routing new-routing-mark=to_WAN2
[admin@MikroTik] /ip firewall mangle>> add dd chain=output connection-mark=WAN3_con
n action=mark-routing new-routing-mark=to_WAN3
[admin@MikroTik] /ip firewall mangle>> add dd chain=output connection-mark=WAN4_con
n action=mark-routing new-routing-mark=to_WAN4
1.0/24 action=accept in-interface=Local
asquerade
asquerade
asquerade
asquerade
[admin@MikroTik] /ip firewall nat>> /ip dns s set allow-remote-requests=yes cache-m
ax-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=221.132.112.8,8.8.8.8
bad command name s (line 1 column 9)
[admin@MikroTik] /ip firewall nat>> add dd chain=srcnat out-interface=WAN4 action=masquerade
In that last command, you have an extra s after dns.
Sent from my DROID4 using Tapatalk 2
what is wrong in this line?
You really need to read the documentation so you can see the correct syntax for these commands.
Anyway, in that command, you have an extra “dd” after the word “add”.
It should be “add chain…” NOT “add dd chain…”
@Robotics909
Disable console ‘HotLock’ mode as described in Wiki:
http://wiki.mikrotik.com/wiki/Manual:Console#HotLock_Mode
In this mode ROS is trying to autocomplete every command, hence errors like ‘add dd’.
HTH,
