Hi
I have a brand new routerboard 750 gl with.while I am trying to configure it after connecting the lan cable to my pc ,the connectivity with my pc is gets disconnecting regularly.(In other words the RB is keep on getting rebooting)not stable.
set up ip address or use one that is set in default configuration and configure your PC according to config to connect to. As you most probably are connected using MAC address.
