I have mikrotik routerboard 750gl software version 5.2 , 5 ethernet ports . i user 4 ports for wan contections and one port for lan conections .
i cant access http interface for these 4 wan interface ... i mean that i cant access the web interface for every adsl modem for these 4 wan intefaces. but internet connections run very well ..
thanks
here is all rules :
add address=192.168.1.2/24 broadcast=192.168.1.255 comment="" disabled=no
interface=in1 network=192.168.1.0
add address=192.168.16.2/24 broadcast=192.168.16.255 comment="" disabled=no
interface=in2 network=192.168.16.0
add address=10.0.0.139/24 broadcast=10.0.0.255 comment="" disabled=no
interface=in3 network=10.0.0.0
add address=192.168.10.2/32 broadcast=192.168.10.2 comment="" disabled=no
interface=in4 network=192.168.10.2
add address=192.168.20.1/32 broadcast=192.168.20.1 comment="" disabled=no
interface=out network=192.168.20.1
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:F3:8D
master-port=none mtu=1500 name=in1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:F3:8E
master-port=none mtu=1500 name=in2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:F3:8F
master-port=none mtu=1500 name=out speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:F3:90
master-port=none mtu=1500 name=in3 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:F3:91
master-port=none mtu=1500 name=in4 speed=100Mbps
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
192.168.1.1 routing-mark=in1 scope=30 target-scope=10
192.168.16.1 routing-mark=in2 scope=30 target-scope=10
10.0.0.138 routing-mark=in3 scope=30 target-scope=10
192.168.10.1 routing-mark=in4 scope=30 target-scope=10
192.168.1.1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=
192.168.16.1 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=3 dst-address=
0.0.0.0/0 gateway=10.0.0.138 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=4 dst-address=
0.0.0.0/0 gateway=192.168.10.1 scope=30 target-scope=10
/ip firewall mangle
add action=mark-connection chain=input comment="" disabled=no in-interface=
in1 new-connection-mark=in1_conn passthrough=yes
in2 new-connection-mark=in2_conn passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=in1_conn
disabled=no new-routing-mark=in1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=in2_conn
disabled=no new-routing-mark=in2 passthrough=yes
in3 new-connection-mark=in3_conn passthrough=yes
in4 new-connection-mark=in4_conn passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=in3_conn
disabled=no new-routing-mark=in3 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=in4_conn
disabled=no new-routing-mark=in4 passthrough=yes
add action=mark-connection chain=prerouting comment="" disabled=no
dst-address-type=!local in-interface=out new-connection-mark=in1_conn
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/0
dst-address-type=!local in-interface=out new-connection-mark=in2_conn
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/1
dst-address-type=!local in-interface=out new-connection-mark=in3_conn
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/2
dst-address-type=!local in-interface=out new-connection-mark=in4_conn
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting comment="" connection-mark=in1_conn
disabled=no in-interface=out new-routing-mark=in1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=in4_conn
disabled=no in-interface=out new-routing-mark=in4 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=in3_conn
disabled=no in-interface=out new-routing-mark=in3 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=in2_conn
disabled=no in-interface=out new-routing-mark=in2 passthrough=yes
add action=masquerade chain=srcnat comment="" disabled=no out-interface=in1
add action=masquerade chain=srcnat comment="" disabled=no out-interface=in2
add action=masquerade chain=srcnat comment="" disabled=no out-interface=in3
add action=masquerade chain=srcnat comment="" disabled=no out-interface=in4
i mean that I cant access for example web interface for 192.168.1.1 , 192.168.16.1 , 10.0.0.138 or 192.168.10.1
sorry for my english
thanks for help
