hi,
I am running dude on a RouterBOARD 750G r3.
Although it look like the device is capable to do hw offload it seems not to work …
system routerboard print
routerboard: yes
board-name: hEX
model: RouterBOARD 750G r3
serial-number: xxxxxxxxxxxxxxxx
firmware-type: mt7621L
factory-firmware: 3.35
current-firmware: 6.46.6
upgrade-firmware: 6.46.6
interface bridge port print detail
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
0 interface=ether1 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query fast-leave=no
1 I interface=ether2 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
2 I interface=ether3 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
3 I interface=ether4 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
4 I interface=ether5 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
there is no H on the interfaces …
export hide-sensitive
# may/28/2020 20:18:16 by RouterOS 6.46.6
# software id = LY3V-DSG4
# model = RouterBOARD 750G r3
# serial number = xxxxxxxxxxxxxxxxx
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no name=bridge
set [ find default-name=ether1 ] comment="uplink"
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=all
/ip dhcp-client
add disabled=no interface=bridge
/ip service
set telnet disabled=yes
set www disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system identity
set name=dude
/system logging
add action=disk topics=warning
add action=disk topics=info
add action=disk topics=error
add action=disk topics=critical
/system ntp client
set enabled=yes
/system routerboard settings
set auto-upgrade=yes
any suggestions ?
sindy
May 28, 2020, 6:30pm
2
All the bridge ports but one are inactive… what happens if you connect another cable to one of the unused ports? The HW offload means forwarding of frames among ports by the switch chip itself.
I had port 5 connected and the H was not there …
sindy
May 28, 2020, 6:53pm
4
No more ideas then. There is nothing in the configuration which would explain that.
Jotne
May 28, 2020, 9:11pm
5
I do see the same as you .
750G r3
/interface bridge port print detail
0 I interface=ether3 bridge=Bridge1 priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes
auto-isolate=no restricted-role=no restricted-tcn=no pvid=20 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
1 interface=ether4 bridge=Bridge1 priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes
auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
My hAP ac2 is ok
0 I H ;;; defconf
horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no
1 I H ;;; defconf
2 H ;;; defconf
McSee
May 28, 2020, 10:50pm
6
Set STP on the bridge to none .
somehow setting STP on the bridge to none made the H appear …
but WHY ? all my other type of devices are running RSTP and do show the H …
0 H interface=ether1 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all
1 I H interface=ether2 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
2 I H interface=ether3 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
3 I H interface=ether4 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
4 I H interface=ether5 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
Jotne
May 29, 2020, 5:35am
8
My STP was set to none and showing no Hardware Offload.
Did try to change to STP stil no HW, then back to none, still no HW
6.45.8
awbl
May 29, 2020, 5:55am
9
I saw you have a PVID assigned on a port. Are you using VLAN filtering in your bridge? If so, that’s the culprit. See the table here: https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Bridge_Hardware_Offloading . The 750GR3 uses the MT7621 chip.
Jotne
May 29, 2020, 6:27am
10
Yes I do use VLAN, did forget abut this table
eddieb
May 29, 2020, 6:38am
11
tnx for pointing to this documentation.
I think I can live with no HW acceleration on my local dude server …
