RouterBOARD 751U-2HnD and version 5.11-5.13 problems
I have Routerboard 751U-2HnD and i like this routerboard. Good! I have little problems from router , thats v5.13 software.
I take downloading v 5.13 and flashing and today my router is crashing
no internet
no wireless SSID
restarting router and no fix problems
ONE led switch active and no more led
Im resestting this router and router is over
no mac aadress login in
no connect to netinstalling
Before software 5.11 is ok if im take and thinks 5.13 is ok and i dont know , whats is problems.
Hi!
My RB751 working like a charm on ROS5.13. Try to reset rb.
this router is dead , im can new router and v.5.11 is ok and no problems
The same thing happend to my two routers , one RB 750 and one RB751 . They were working fine couple of months but with the 5.13 version they’re not working any more. All my configuration were lost . :frowning:
cpu overload fully ? and router dead?
I have the same problem :frowning:
I sent this RB to RMA, but result is router board OK…
How you resolve your RMA ?
Thx
Karel Peran - Nunak
this router is cpu overload fully and dead?
I had an issue upgrading my RB751 from 5.13 (i think) to 5.14 where it crashed after upgrading and had to be reset before it would respond at all
I don’t know what do CPU, because mirotik will crash and is not possible read cpu status. And little important think i have the same problem on 5.14.
What i read in this forum is a HW problem, but my reseller have problem with RMA. Something about 50$ for RMA from Mikrotik.
Karel Peran - Nunak
I don’t know, but I think that this 5.13 is corrupt. I have had this problem, and that I put your router does no longer 5.13 gone go and made reset. I give it to the my reseller and have replaced the me-new and currently is on the software version 5.11.
I think that bad software but also to section 5.14 is uncertain. I did not dare any more to put up any new software other than as the same thing could happen again.My reseller told that it is a software error and something related to overfully 100% CPU and router dead.
My suggestion, do the things that people here can be a leisurely time with regard to not worry about a router
