I’m using one of these for the first time, and have it installed. I’ve been using non-wireless RB433G for a while and it is running 6.14 (or whatever the latest RouterOS is)
When I went to make sure my 751U-2HnD was up to date, i noticed it is on 5.26 from the factory. When I updated it, it said there is no updates available. (Packages → Check for updates).
I don’t see anything that says the 751U-2HnD runs on a different version of software. Can I confirm from someone that 5.26 is the right software version or do I need to update this to the latest via another method besides packages → check for updates?
Thank you
