RouterBOARD 751U-2HnD & Vodafone 3G
Hi All,
I am a complete newbies when it comes to configuring RouterOS, although I can manage with some things, I am battling with the following.
I would like to achieve the following.
  1. Create a Wifi Network for my House, with Passphrase - Done, tested and working.
  2. I don’t have a ADSL line , so I would like to use my Vodafone 3G Dongle (K3565-Z) which is supported as my “internet” device. I would like the RouterOS to control the connection etc, and provide internet access via the wireless which has been setup.
  3. I have tried all different settings, and cannot get the device to connect. I am not sure what to use for the channels etc.
I will provide any info that is needed.
Please help
SOLVED: Was a NAT issue, select pop-out1 and all is working.
Though it is a solved problem but also now i am telling that using Vodafone 3G wireless connection is out of various problems. So, i think you should use Vodafone 3G wireless connection to ignore various problems.
