RouterBOARD 941-2nD slow speed at PPPoE
Hi ,
I changed the vdsl link form 20/2 to 50/8 Mbps but current RB941 2nD can not can not reach speeds greater than
20 / 7 Mbps . OS :6.42.12 long term , fw: 3.22 (factory) 6.42.12 current . CPU: 650MHz .
No firewall rules ,fasttrack connection added . Tried with another one , same result .
Old RB951G works at about 43/7 Mbps with same PPPoE settings and router parameter .
Laptop connected as PPPoE client works at ISP rated speed .
Is it possible to fix this or II need to replace the device with something else ?
