The 951-2n is a nice sized and affordable router for home and small business use. We seem to have a high failure rate with the things. After power cycling the things will just have steady power and activity lights and none of the ports will light up. Anyone else having issues with them?
Deleted because not related.
I don’t think that this device was designed to only be an AP only. It is being sold as a small office or home router and AP. The specs on this device are sufficient for most small buildings with limited wireless device access and moderate internet speeds.
I have had one of these providing 16/3 internet with DNS, dhcp, sstp client, wireless, etc for months with no issues.
I would not use this device for thousands of routes or dozens of vpn connections as this device was not really designed for this purpose.
Sent from my Nexus 7 using Tapatalk HD
a lot of crap and to much free time …you always blame the user, not helping.
So how does the 951-2n being under powered cause it to brick after a power cycle or firmware upgrade? It works fine when its working but I have had 4+ die now and it seems to always happen after a power cycle of some sort. They work great when they work and I am using one at work and at home right now. I just did a speed test at home accross wifi and can do 22mbps by 10mbps and thats what the PPPoE profile is set at. I can do a linux ISO bittorent download at 20mbps and CPU load on the 951-2n seems to hang around 20 percent mark. Thats running through PPPoE, NAT and wifi all on the 951-2n. And its also doing IPv6 over PPPoE and it seems that most bittorrent traffic went over IPv6.
