I bought those two RouterBoard 951Ui-2nD + ZTE MF 669 and I can’t get it to work.
I see modem in resources but I can’t see anything in /ports.
Please advice what to do ?.
Regards,
Regards,
check if you see a LTE interface in the list?
Also maybe your modems CD-drive interface is enabled. You can disable it when you connect the modem to the PC and execute the settings like in this manual:
http://www.3g-modem-wiki.com/page/ZTE+AT-commands
After that try to plug the interface back to the router.
