I have a RB532 and a server that I want to do transparent proxying on. In the manual it says i should use the RB to route between the internet and my local network, thats easy enough.
But should I put my proxy inbetween the RB and my local network? If I do that how should I configure the network interfaces on the proxy server?
I am wanting to run Dansguardian content filtering, but I do not want it to be bypassed, hence I want it to be transparent. I will have SME server running as a server/gateway with Squid and Dansguardian.
use transparent proxy - forward all the requests to 80 to your proxy and do there anything you want and nobody can bypass you, except they conenct on other port
