aamikro
December 16, 2009, 9:55pm
1
I have several Routerboard 750 installations and everything works great.
However I can’t query the SNMP of the RouterBoard itself form the WAN interface.
Is this possible? How can I accomplish this?
Firewall is open and SNMP is enabled in the Routerboard…
Thanks!
Pada
December 17, 2009, 2:31am
2
I have a RB750G with ROS 4.3 and my SNMP is working just fine from both the WAN & Local interfaces.
Ensure that SNMP is indeed enabled AND listening on 0.0.0.0/0 or at least the address of your WAN interface.
To check if its enabled, type the following in the Terminal: /snmp print
To check if its listening on 0.0.0.0/0, type in: /snmp community print
aamikro
December 17, 2009, 5:21pm
3
Thanks Pada.
I upgraded to 4.3 and now SNMP works. However the RouterOS tab in The Dude is now empty and
the tab “Dude” has only the symbol “:”.
Any clue?
Thanks again.
Pada
December 17, 2009, 10:55pm
4
Maybe you should update the Dude? I haven’t used it yet, so I can’t say why that would happen. I’ll test it tomorrow, I’m simply too tired atm
