Suddenly came up stupid idea in my head, when I researching barcode reader. Is there any possible way to receive 12 digits from Serial interface send this text to the somewhere over TCP?
Please post here your comments even you don`t have idea or experience.
So I’m assuming you’d hook up the bar code scanner to either the USB port or the serial port. Someone would need to write a driver. Someone would need to write a module that either encapsulated the data into TCP and sent it to a destination address…and again someone would have to write another program to receive the data. Alternatively you could take the data and put it in a file on the RouterBoard.
Why? Lots of products out there that already accomplish this - there are even wifi enabled barcode scanners and whole POS (point of sale) suites of software. Granted at ridiculous and astronomical prices.
We’ve already got a long list of current features that need debugged. No point in distracting folks.
Thanks for your suggestion MacLean. We need specific environment that need to check code. But database is faraway from barcode readers. So I researched some Android OS and Windows mobile OS based programmable terminals. But they are expensive. Also I need to find coder who can develop client application.
If routerboard can forward RS232 or USB inputs directly to my SQL server, it will be very cheap and easy solution. Of course, in the server side we need application that receives code, checks and responds back.
You’re looking at the wrong hardware, it’s a router at heart.
I would recommend looking at Android based tablets and Bluetooth scanners. You will probably be a couple hundred dollars into each, but way more flexibility.
A Raspberry Pi would probably be much more suited to the task. It should be pretty straight forward to whip up a python script to read the data from your actual barcode scanner and send it to SQL then flash some LEDs to show it worked
Thanks for your suggestion. Yes, thats what Ive done. My programmers developed JAVA application on android terminal and it connects to my server, which is Python software.
