Routerboard CPE
Can we expect to see a CPE that will fit in a small form factor antenna pouch much like pacwireless has with their routenna’s.
The reason I ask is because the RB100’s do not fit in the 900mhz routenna’s and they do not have a pouch any deeper than 1" (25mm) available.
I’ve made them fit by doing some custom fabrication, but long term I don’t think it will be reliable.
yes
when?
+1
Be sure to check Linux Journal - this is where to find new MT hardware first.
Hmmm! Nothing found there when I did a search for Mikrotik or RouterBoard.
a search in a paper magazine :slight_smile: ?
