Routerboard Hardware wish list
Hello, everyone!
Thanks Mikrotik team for looking after our everyday needs and bringing new gear to us on regular basis.
unfortunately there are still some gaps to fill :slight_smile:
still waiting for Mikrotik team to release dual polarity high gain cpe (analogue to ubnt nanobridge M5-25) with nice parabolic reflector, integrated radio, just plug in ethernet cable :slight_smile: same as great sxt, but for distances like 10-20km.
Second thing I would like to see competitor to ubnt toughswitch with gigabit poe and RouterOS functionallity, something like 1100AHx2 with 12 gigabit PoE out ports!
I believe, i am not only one who is waiting for this kind products!
Darvnieks, what about the SEXTANT G?
23-25dbi antenna would fit the bill. Also a 2ghz with 27-30 dbm with 19dbi antenna would be great.
Sent from my iPhone using Tapatalk
I would like to see RB951-2Hn with external antenna connector. Nothing more.
Do not consider a RouterBOARD device with SFP interface? Any timeline when SFP will come?
We already have many products with SFP. See our website: www.routerboard.com
My Wish List:
  1. An internal AP with “beamflex” Ruckus style antenna. Either 802.3af compliant or Mikrotik make a bigger PoE switch.
    Also this AP must blend in well with its environment such is this Zyxel or the Ubti internal APs.
    http://www.zyxel.com/uk/en/products_services/nwa1120_series.shtml?t=p
    I would prefer 802.3af compliant as nearly all business class APs have this.
  2. RB450G updating to stay competitive with the new RB-2011 series but keep its same form factor.
  3. 12 Port PoE switch
  4. Option to buy rackmount equipment unbranded
  5. VDSL/ADSL built in to a RB
  6. Central AP controller building into ROS
lol I don’t want much :slight_smile:
I need a RouterBOARD model RB411GL or RB411L with a SFP interface. I need to connect radios with interface fiber.
+1
We already have many products with SFP. See our website: > http://www.routerboard.com
I need a RouterBOARD model RB411GL or RB411L with a SFP interface. I need to connect radios with fibre interface.
+1[/quote]
+1
PoE switch or 8 port PoE anapter…
Want to see
Mikrotik Lan Tester
+1 For higher gain SXT (25dBi).
Would also love a 16 port GB POE switch/router otherwise I am going to have to settle for tough switches.
Something akin to the Patriot Gauntlet and Seagate wireless HD enclosures. Also would like a variant that has both sata and mSATA and raid capabilities.
-Mac
+1
Wishing
RB750 UP with Gigabit
and a 8 Ports version will be nice
We would like to see a CCR with 24 copper GigE and 4 SFP+ with two hot-plug PSUs (DC and AC option).
This would be a real enterprise/ISP device.
  • Mat
:slight_smile: Fiber switch with 6 or more integrated SFP
+1
My wishes for desktop routers:
  • No more gigabit+fast, all gigabit, I guess 12 ports is the next step.
  • But 2 rows of ports, so that the unit can be narrower, but it should fit on a 1U drawer.
  • An external plug for the power supply
  • A power switch
  • A cheap BaseT SFP module so that I can use the slot for something (not interested in rewiring for FTTH)
  • A VDSL2 SFP module, better.
  • Simultaneous dual band, or the wireless is not interesting
  • Wireless faster than 300Mbps
  • Replaceable wireless card
  • Standard USB port, not mini
  • USB usable for terminal access
  • PoE+ supply on all ports, but maybe with limited budget so as to keep the unit fanless
  • Faster in order to support some UTM functionality, but keeping fanless
  • Cheap and low-power short-range 10GBaseT on some ports to move mainstream computing forward, but keeping fanless
  • LEDs that can change colour in each port, not all together
  • SODIMM slots, but keeping small
  • XQD slot, but keeping small
I profit to emphasize some software points:
  • Ability to shutdown and reset from the touchscreen
  • HFS+ and AFP support
  • Support internal forwarding of link-local packets which do not break the network (e.g.: mDNS)
  • Write all desktop software in a truly portable manner.
