routerboard like 800 but pci-E
how soon can we see a routerboard… like rb800 but with 4/8 pci-E?! with expansion board and stuff!!
you should know that we are not commenting on products that are not on routerboard.com
Hello ffernandes,
if you are looking for a real MikroTik RouterBoard it`ll be not able to serve your wishes
but if you can life without the MikroTik logo but RouterOS is running on the machines
I would suggest to take a look a the newest Soekris or PC Engines Alix boards.
  • PC Engines Alix APU Board is sorted with 3 mini PCIe slots ready for mSATA, modem or WLAN
    Alix APU Board with GB LAN ports and 3 miniPCIe slots
  • Soekris net6501 is ready to hold two MikroTik RB14eU cards with 4 miniPCIe cards on
    each board, so you are able to reach your goals more or less.
    Soekirs net6501
    — Desktop case is able to hold one RB14eU
    — 19" rack mount case is able to hold two RB14eU
  • At the Varia Shop you are also able to order some 19" cases with mounting plates
    that would be able to hold two brand new MikroTik RB953GS-5HnT boards you will only
    need two of them to reach your goal. I know it is not exactly what you are searching for,
    but you will also see that workarounds are given and existing.
    RB953GS-5HnT picture
